05:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently using Recap Pro to try and register and index a project of 70 scans from a Trimble TX6. I have exported the files as e57s which have correctly imported and registered however when I try to index the scans Recap just sits at 0%. I have used the system manager to check the CPU and RAM usage and MSI afterburner to check the GPU usage and Recap does not appear to be doing anything.
Has anyone else had this problem or is there a log file I can look at to see what the issue is?
