Recap Pro - "Launch Project" button doesn't do anything when clicked
tom_ayre
Message 1 of 18
tom_ayre
When clicking on the "Launch Project" button on recap nothing happens? I have previously registered the scan data together and launched the project.
I'm wondering if it has anything to do with the project file being xref'ed into an AutoCad drawing I am working on?
I have tried restarting the computer, making sure Autocad has closed etc but nothing seems to allow the project to launch!
Any suggestions?
Replies (17)
Message 2 of 18
anil_mistry
Autodesk Support
Autodesk Support
Hi @tom_ayre,
Thank you for participating in our Community! Looks like ReCap is still indexing your project. You have to wait till its finish indexing before lunching project. You can see progress on progress bar. Please, let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 3 of 18
tom_ayre
Hi Anil,
Thanks for the reply.
The bar at the bottom doesn't move from 0%, it's like it is stuck?
Message 4 of 18
tom_ayre
To add to my previous comment, I can still go back to the home screen so the program hasn't crashed?
Message 5 of 18
anil_mistry
Autodesk Support
Autodesk Support
Hi @tom_ayre,
Looks like there are many scans in your project. I would let it finish processing before you kill the process.
Anil Mistry
Message 6 of 18
tom_ayre
Hi Anil,
Time hasn't helped, its seems to be stuck at 0%, any ideas?
I've noticed that a few of the scans are saying "pending" which might be holding things up perhaps? So frustrating.
Message 7 of 18
anil_mistry
Autodesk Support
Autodesk Support
Hi @tom_ayre,
I would try creating new project with scans that were able to process and then add those scans that are showing up as pending. Let me know if this helps.
Anil Mistry
Message 8 of 18
anil_mistry
Autodesk Support
Autodesk Support
Hi @tom_ayre,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 9 of 18
syrine76
Observer
Observer
I have the same problem but the bar at the bottom is at 100%
Message 10 of 18
n.kamphuis
Have you found a solution for this? I have the same problem now...
Message 11 of 18
daniel_lazarQ8WHZ
Community Visitor
Community Visitor
Hi, I have the same problem with my project. None of the following solutions have helped me.
Message 12 of 18
barmanr
Hi @daniel_lazarQ8WHZ ,
Which version of ReCap are you using?
Would it be possible to share your dataset for validation on our end? If Yes, I will PM you a private one-drive link.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
Message 13 of 18
mairh_tsek
Hello @barmanr
I have the same problem in Recap Pro. The bar is completed 100% but the 'launch project' button is grey out.
Message 14 of 18
barmanr
Hi @mairh_tsek ,
Would it be possible for you to share the dataset with us?
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
Message 15 of 18
joelsj
Same problem here. Launch-button greyed out.
/Joel
Message 16 of 18
barmanr
Hi @joelsj ,
May I know which version of ReCap Pro are you using?
I just gave it a try with the sample file you shared and I was able to Launch the Project using ReCap Pro 2025 after import and index.
Warmest Regards,
Rishov Barman
Reality Capture
Message 17 of 18
joelsj
Message 18 of 18
joelsj
Now it works! Installed the latest hotfix for 2023.
