Recap Pro Questions
I have a few questions / requests that I hope to get answered about ReCAP pro.
1. If color scans are done, the default view when registered is RGB. Can this be changed to an intensity view for registration instead?? I find that the colors can often be overexposed, so the intensity is easier to work with. I can't seem to change to intensity until after you index.
2. I referenced the scan to survey control, and the coordinates are large since they are in a transverse mercator projection. The registration goes great, and I apply the control and happy with the fit, but after indexing the points aren't visible at all. I assume this would require updating the origin, but is there another way to update this without seeing the points?? Could it not use my home scan as the origin, or allow me to enter coordinates for the origin??
3. When the scans are registered to survey control, it is great to see the results during the registration, but it doesn't seem to be available after the registration. Can this not just be appended to the Registration Quality Report file??
Thanks.
Kevin
