We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
Recap Pro Clean-up Limit
Bonjour,
I've been using Recap Pro (trial so far) for a couple of weeks to clean up point clouds filled with moving people or cars. It's been pretty efficient for projects of 10 to 20 fls or e57 files I would say, as I'm still trying to assess the  "competences" of this tool.
I then wanted to clean-up a 88-pointclouds project (e57 files, colors applied, full resolution) and the result is that Recap detected no point to be cleaned at all (see attached image)! I am pretty suprised since I clearly see stuff that needs to be removed. It took a long time importing, registering, processing, all that for nothing (more than 1 day at the office spent on that).
So I would like to know what are the limits of the tool ? What can I do and what can I not do ?
Will it work better if I split the global area in smaller parts / projects ?
miguelantunes1992
I always clean manually, try to clean with the fence or plan tool
Yeah I had to do that eventually, using Faro Scene 7.1.
The point of this tool is to save time by removing points automatically, I'm not sure I will get to use it after the trial period.
Anyone from Autodesk to answer my initial question ?
Dear @anil_mistry,
Maybe you can help me with this situation ?
Can you explain how the clean-up works in a few words ? Does it only select points that are only seen in 1 scan in comparison to others ? Why doesn't it select moving people sometimes?
thanks
Thanks Miguel,
I've read this documentation already before downloading Recap. Unfortunately it does not answer or resolve my problem.
I tried with 2 sets of 7 scans on the same project (instead of 88 total), the clean-up does select points to remove even it's not perfect in each case.
Dear @anil.mistry,
I am still hoping for an explanation about the limit of the clean-up tool in Recap Pro. I have 5 days left for the trial version, I won't be able to give enough good arguments to my boss if I can't solve this.
Are you aware of this issue? are you working on it for a future update ?
Kind regards.
Julien
