I do have not much more information to share other than that I got an error message
Because of the lack of more clues, it might be best if Autodesk took a look at this.
I can submit this case to the Autodesk Partner Page, but thought it would be more useful for everyone to take part in the problem and solution here at the user forums.
Basically, this is what I got
Some information
- the project is Aerial, and it has no GPS location, and hence will not be geolocated, which is fine. The reason I choose Aerial is the 300 photo limit on "Object" projects. I wanted to try out both, to compare the model quality.
- The images are rotated if that could be causing some problems. I have had success with rotated photos, so I did not bother to rotate them correctly for this project. But please let me know if there is a best-practice
@barmanr - I saw you support similar posts before. I pm:ed you a link with the dataset.
