Recap Photo needs to take a lesson from Pix4d and Agisoft
gamehenge757
gamehenge757
I've wanted recap photo to work for our organization, but the results are horrible.  The exported .tif files are a terribly low resolution for the size of the image, and the points clouds are far too sparse, requiring a lengthy work around to become just a tad bit more dense.  Does autodesk have any plans to make this software usable? I've run the same dataset using recap photo/recap, then in agisoft photoscan and pix4d and the latter two have a MUCH higher resolution threshold on the exported .tif, plus the ability to export a world file.  The point clouds in both come back remarkably clearer and more dense, and they can both process nadir/non-nadir photos at the same time to give a much more precise 3d model.
So before i decide to ditch recap entirely, has anyone had any usable results?
anil_mistry
Autodesk Support
Autodesk Support
Hi @gamehenge757,
Thank you for participating in our Community and providing great feedback! I will forward this to product team on your behalf.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
gamehenge757
How about instead you detail the method in which to combine nadir and oblique photos into a model to build a precise point cloud? as well i'd appreciate any feedback on how to make the point cloud much more dense while retaining the projection of the project.
Agree with your suggestions; but might want to explore curved flight paths along with the oblique photos.  I've attached an example of curved flight paths for comparison - avoid turning loops with fixed-wing drones and the stopping at the ends of straight/parallel flight lines which burns batteries.AK Open-pit Mine Curved Flight Lines.jpgLog-spiral flight lines.jpg
