Recap mesh not availble
dbonetti
dbonetti
I have opened an XYZ file in Recap and cleaned it up but I the Mesh function is grayed out.  I just downloaded Recap Pro as a student.  Ultimately I want to create a solid I can use in Fusion360.  Am I approaching this the right way?  Is there another software I should use?  Thanks for any help.
anil_mistry
Autodesk Support
Autodesk Support
Hi @dbonetti,
Thank you for participating in our community! Please see accepted solution from this post for more information. Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
dbonetti
Thank you for your response.  So I can't create a mesh from xyz data?  What do I need to do in order to do this?  Is there another Autodesk product that I can use to get this to work?
anil_mistry
Autodesk Support
Autodesk Support
Hi @dbonetti,
Thank you for your reply. I am sorry but Object Mesh only works with Structured scans and XYZ is not in structured format. I am not aware of any other Autodesk product can create mesh from XYZ data.
Anil Mistry
