Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Recap low point loading ability
I use point clouds every day and at this moment I don't use recap anymore for editing my point cloud, because the reason of it can't load as much points as AutoCAD( it can load 10 million) which for the scale of work I do that seen as a smaller point cloud , I do plant work and recap is of no use to me....If I am wrong and recap can handle more points please respond with an answer, it could be the graphics card which I doubt
vidanom
Can you give us more details why you are not able to load scans with more than 10M points?
Which file format are you trying to import and from which products it’s exported?
Is there some error message that you are receiving?
On the image attached, on only one scan the points number exceeds 300M, 6GB of file size.
The limit how many points and file sizes can ReCap index should be extremely high.
Best,
Miki
jnelson1071
Do you have a ballpark of the limit on file size?  We have a 32.6gb PTS file and it goes to about 25% and then fails loading the PTS.  I have a request in to scanning provider to split to seperate scans, but it would be nice to know that limitation.
Jeremy
