I'm using the latest version of Recap Pro and when I try to export a file in e57 format Recap crashes. I checked my graphic card, processor, etc., everything seems fine with my workstation. My operating system is Windows 7. With the previous version, exporting to e57 format worked just fine. Any idea of what could cause this problem?
Solved by ashwini.murthy. Go to Solution.
Hi @Guy_Cote,
Not sure what it could be wrong. Did you submit a crash report?
There is a new release that just came out today, but I'm not sure if that will solve this case.
I'll let the team know if they can investigate.
Is there anything that you did differently with this project?
Thank you,
Mitko
Recap crashed when trying to export in e57 file to an other directory than the one where was created the rcp project.
Sorry that you are experiencing this issue. I will try to find your CER and send it over for investigation. By any chance do you have the CER report ID or the email address that you used to submit the report?
Couple of quick questions:
Did you do a "Complete" or "3D only" export?
Do you have enough space on disk?
How big is the project you are trying to export?
Ashwini
Complete or 3D only gives the same result.
Yes, There is enough space on disk.
The project is small (few scans). I try to save one scan at the time in e57 format.
Recap gives a Runtime error??? See image in attachment.
Very strange. I did some tests and works fine for me. Would you be willing to share your Recap project with me for investigation ? If Yes, I can share a box folder with you.
Ashwini
It works fine when I work on an amovible disk connected on my computer. So, it doesn't seem that the problem is the project. The problem occurs when this same project is on the "Documents" directory....it is like Recap could not connect with this directory when exporting an e57 file while it works fine when exporting an pts file or any other file format????
I had the same issue with 4.0. I use the export to .e57 to write out data that has been registered and I want to have the info stored for each scan. I never had this issue till 4.0. I rolled back to the previous version and the same project exported with no issues.
Hi Ron,
I heard a similar issue recently. Thanks for reporting. We will try to reproduce this and find a solution.
Ashwini
