I have some questions on the multi-threaded benefits of working with point clouds in ReCap and other Autodesk products. I have a test system with dual 18 core Xeons (36 cores, 72 threads). When loading/manipulating certain point clouds in ReCap, I notice it that all of the cores are being used, although not quite at 100%. Other point cloud data only use a single CPU core.
The point cloud data set that uses 100% of the cores has RGB color data while the data set that seems to be single threaded does not seem to have color information. The color data set is also larger.
Also I notice that when I import the rgb point cloud data into AutoCAD 2015, all 72 threads are being utilized 100%. This shows that manipulating point cloud data in AutoCAD is fully multi-threaded and it takes advantage of hyper threading (ReCap seems to be multi-threaded but does not take advantage of hyperthreading)
Questions:
1) Are point clouds with RGB information the only types that take advantage of multi-threading?
2) AutoCAD seems to be highly multi-threaded with point clouds. What is the actual benefit of using many CPU cores. Is it faster load times? Faster interactivity? Both?
3) I'm curious how other Autodesk apps handle point clouds. I've tried 3ds Max and it doesn't seem to utilize hypertheading. Is Revit, Navisworks and Invenor as efficient as AutoCAD??
Note: I'm not a user, just trying to understand the real compute requirements. I attached a screen grab of AutoCAD using 72 threads.\
Thanks all!
Joe Pizzini
BOXX Technologies
