I just downloaded the latest version 4.0.0.28, and it seems as though it is running as administrator every time.
Our IT department does not trust us, so we are no longer Administrators on our own machines, and it is asking for a password to run the program itself.
Is it possible to change this, as it was not an issue with any older version?
thanks
Solved by jasonbayer7965. Go to Solution.
Got it.
I had to locate the program on the start menu, properties, compatibility and uncheck run as administrator.
weird how it installed like that, I have never had another program install and default to that.
Thank you for letting us know.
We'll see if there is something that we need to readjust with the installer.
Thank you,
Mitko
I wish version 4.0 would show up under my contract portal for download.
