Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
RealView for NavVis e57 (images embedded)
1 REPLY 1
PCansel
689 Views, 1 Reply
NavVis (www.NavVis.com) is a 3D Scanner Mobile Slam based manufacturer. We can export the data as e57 (with embedded images). However, when we take the data into Recap (and pro), we don't get the "Realview", so-called Bubble views. One might think that as the system is Mobile/Slam, the e57 is unstructured and hence one should NOT expect the "Realview". Nevertheless, there are certain viewers that can show the bubble view from very same e57 that Recap fails to do so. Not sure if something should be done on e57 prior/post export or there is a work around workflow. I believe many people are eager to know about this.
1 REPLY 1
Hi @PCansel
We are discussing a very similar case in this thread https://forums.autodesk.com/t5/recap-forum/can-not-get-the-mirror-balls-when-converting-e57-files-to...
Specify in which software did you manage to import the unstructured point cloud together with realview?
Maksim Melnikov LinkedIn | Instagram
Autodesk Solutions Expert
Autodesk Certified Instructor
Rail Community
