ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Publish to Drive Error
2 REPLIES 2
mikeM9TCU
557 Views, 2 Replies
I have imported an rcs file from a Trimble scanner.
When I try to publish to Autodesk Drive, receive this error:
"The selected connected drive only supports structured scan. Please select other connected drive."
How do I fix this?
2 REPLIES 2
barmanr
in reply to: mikeM9TCU
Hi @mikeM9TCU ,
Unstructured point clouds are not supported for Autodesk Drive. Autodesk Drive only supports real view publishing which means scans with real views. In order to publish unstructured point clouds, you'll need to publish to either BIM360 or Autodesk Construction Cloud.
Thanking You.
Warmest Regards,
Rishov Barman
Reality Capture
nevesW4L86
I'd like to share an unstructured Recap file online with someone who isn't a member of the Bim360 project. When I share a public link it just gives them the ability to download, instead of the ability to use the Recap web interface the way project members can. Is there a solution to this? I thought I'd use Autodesk Drive but it didn't work and that's how I ended up on this thread. Thanks.
Rail Community
