Project Didn't stitch with unknown failure
akeyXHWHT
Message 1 of 11
akeyXHWHT
I upload two drone missions to the cloud on Sunday.  One stitched and processed fine and the other didn't and says "Project failed with and unknown error."  The photos all appear fine and the flight path was steady.  Can someone reach out to me to have it reprocessed?  The project in the cloud is called 15153ThomasRd
Austin
Replies (10)
Message 2 of 11
barmanr
Hi Austin,
We will resubmit the project for you. Could you also PM me your Autodesk Email ID please?
Warmest Regards,
Rishov Barman
Reality Capture
Message 3 of 11
akeyXHWHT
akey@gymodpc.com
Message 4 of 11
barmanr
Hi Austin,
We resubmitted the project but it has failed at the same point at the 3D matching step.
Any differences between the 2 different projects you ran? Or survey information used? And the camera models?
If it's possible to share the set with me, I will validate it directly with the engine. If Yes then I can PM you a one drive link where you can upload the dataset.
Warmest Regards,
Rishov Barman
Reality Capture
Message 5 of 11
rconde
Hello, I have the same problem. I uploaded a drone mission to the cloud and photos did not stitch. I uploaded the project twice.
Message 6 of 11
barmanr
Hi @rconde ,
May I have the project name, please?
Warmest Regards,
Rishov Barman
Reality Capture
Message 7 of 11
akeyXHWHT
The projects were flown identically.  Same drone, same settings, same camera. How should I send you the data set?
Message 8 of 11
barmanr
Hi @akeyXHWHT ,
Thank you for the dataset.
I gave a run in both UTM and NY state plane  TCS and in both cases, it failed at feature matching. It does look like our engine is not being able to handle this particular set. I am going to experiment by using a partial set and removing some images to see if we are able to stitch them. Perhaps I will try to remove some of the images in the diamond-shaped flight plan at every intersection and see.
Just a question: Is the other drone set also all greenery?
Warmest Regards,
Rishov Barman
Reality Capture
Message 9 of 11
akeyXHWHT
The other set was the round island set. It was a lot of trees and some of the river. It didn't come out great but it did stitcj
Message 10 of 11
barmanr
Hi @akeyXHWHT ,
I was able to generate a nice result with NY state plane when I removed the green fielded area. I reduced the photos to 154 and all stitched nicely with good outputs. As I suspected the green plains area on the left top corner of the flight plan has too many hard shadows and also those areas are very similar between shots. So I decided to remove them and run and it worked.
I will upload the results for you in the same link as you shared your images.
Warmest Regards,
Rishov Barman
Reality Capture
Message 11 of 11
akeyXHWHT
Thanks for all your hard work!!
