ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
problem whit creation new progect: unable to create project folder try another drive
2 REPLIES 2
1399 Views, 2 Replies
i have a problem whit creation new progect: << unable to create project folder try another driver >>
i try to re-install desktop connector and recap photo, but i have same problem.
how can i resolve it?
i'm using student version.
hardware: windows 10 64 bit, intel xenon e5 v3, graphics card amd r9 280 3Gb.
post screenshot's message error
Labels (1)
2 REPLIES 2
luckybirdie
Hi @Anonymous ,
Currently ReCap Photo officially supports Autodesk Drive and Autodesk Docs (BIM 360) Drive only.
In your case, I suspect that you only have Fusion 360 Drive installed on your machine. If that is the case, I would suggest you setup Autodesk Drive (https://drive.autodesk.com), which is totally free and easy to set up. Once that is done, you may restart ReCap Photo and try to create a project on your Fusion drive again. Hopefully it will then work as expected. Otherwise, you may use Autodesk Drive instead.
Jing
Jing H
Priciple Engineer
rwhi368
in reply to: luckybirdie
I'm having the same trouble as @Anonymous (i'm also on student license) despite having set up and connected to autodesk drive through the desktop connector?
Have i set it up correctly?
Rail Community
