Pipe Snap function does not recognize pipes
YannickElmech
YannickElmech
I tried to measure the dimensions of several pipes in recap pro. However the pipe snap function in Recap Pro does not recognize any of the pipes in the picture. How can I solve this problem?Knipsel.PNG
anil_mistry
Autodesk Support
Autodesk Support
Hi @YannickElmech,
Thank you for participating in our Community! I believe pipe snap function only works with structured scans data. Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
YannickElmech
Hi @anil_mistry,
Thanks for the reply.
I'm using a structured scan I think. When I try to measure large pipes, it works kind of fine. But Recap does not recognize the small pipes (smaller than 5").
Kind regards,
Yannick
anil_mistry
Autodesk Support
Autodesk Support
Hi @YannickElmech,
Thank you for your reply. That's strange behavior. Let me verify with development team and will get back to you soon.
Anil Mistry
sreed
I'm wondering if there is any update to this question.
Also, not really on topic, but somewhat related:
I know there is a way to measure from center of pipe (assuming its recognized), but all i can do is measure to outside diameter of pipe.  How do you toggle from outside to center for pulling measurements?
anil_mistry
Autodesk Support
Autodesk Support
Hi @sreed,
Sorry for delayed reply. I got an update from development team saying that there might be fewer points than required on the small pipes. At this time there is no work around for the released product.
Thank you an have a great day!
Anil Mistry
