- Mute
- Permalink
- Report
Hi All
We tried to create a 3D from photos using recap360 Autodesk. Photos are taken using iphone burst photos feature.
We dropped around 25 photos to create and Recap 360 was successfully creating 3d object and able to see the mesh view mode.
the 3d view is attached (file : test-3D from busrt photos (iphone).jpg)
Then we tried to insert this rcp.file into revit / autocad and receive the message in the image attached (file :failed to insert rcp file.jpg)
we tried to insert this rcp file into Recap Pro software either. Cause previously I thought we could edit / export it to obj format using recap pro.
does anyone know where did i miss the steps? Appreciate if anyone could help to solve the issue.
Thank you
Ivonne
