I'm trying to upload a Recap Pro (22.1) project for the first time to Drive. But after viewing the Help file, I can't follow the directions because there is no Publish icon in the program. Every other option seems to be there.
What am I doing wrong?
Solved by barmanr. Go to Solution.
(Please ignore this reply. Can't delete it.)
Hi @NHHiker ,
Looks like you are using an Unstructured Point Cloud without the Real View (mirror ball positions). This is also why you do not see the Registration button. Publish only publishes the real view along with the scan locations to the cloud hence only for structured scans.
Thanking You.
Warmest Regards,
Ah. Thank you. That was it.
