Assembling a project with about 20 scans.
While registering, we realized the first, or top scan in one of the groups should not be in this scan model.
We cannot figure out how to delete it!
Hovering over any of the other scan locations provides an 'X' to delete the scan location. The top scan in the group does not provide this 'X'.
Any advice on how to delete this top or first scan location from the registration screen?
Currently we are just redoing the project since it's only 20 scans, but we still would like to know how to get rid of that top scan location.
We can't even fake it to use the scan for the final indexing. It crashes before the indexing is done.
Solved by michael.riley. Go to Solution.
Solved by vidanom. Go to Solution.
I believe your first scan cannot be deleted from a registration group. You would have to un-register all of the scans in this group so you can delete the first one and to start a new registration group.
Since you can remove any other scans from a group I'm not sure why this is the case when it comes to the first scan.
I'll check with the engineering team who are all on mandatory week of rest, but I'll let them know as soon as they are back.
Thank you,
Mitko
This is still the case and even worse is that the top level scan is placed there by ReCAP LATER in the registration process. It took a terrible scan, said "we found a match" the preview looked good so you accept. Then what happens when that scan becomes your primary scan location but its totally wrong and you can't remove it? I've got 50 or so scan totally registered. I added one scan (that was horribly wrong) and now I need to grenade the ENTIRE project to start over?
When thinking in complete loops and triangulation, this is a totally flawed way of thinking.
To remove the last scan of a group, switch to that group on the right side and then disband the group:
Then go to the "?" group, which contains all unregistered scans, and delete the scan there.
Hope that helps.
-Michael
Is this still an issue? I cannot delete the top scan and it's very frustrating. This has been a lingering issue for some time, it would be great if it was addressed.
Please enlighten me if i'm missing something.
The post above yours outlines the workflow to delete the top scan of a group. That group must first be disbanded, placing the scan in the "unregistered scans" group, from which it can be deleted. No scans can be deleted when they are in groups - the "x" places them in the "unregistered scans" group. I have accepted it as the solution for this thread.
-Michael
Ah, yes. In that case, switch to a different group (or create a group temporarily using any scan in the "unregistered" group). You can then disband the first group from the right panel.
In that case, you'll need to de-register the last scan of that group to use as the lone scan in a temporary "group 2" to make this process work. It's an unfortunate workaround, but it should work.
I went back and saw your previous post about a rogue scan ending up in position 1. Do you have any other details about when in your workflow that occurred? That is a new one for me, and it isn't mentioned by others in this thread.
The workaround that has been said could be useful.
Maybe it isnt neccesary register all your 150 scan locations again, maybe only one or two.
I suggest this way:
Suppose that the name of first scan location is "A", the one you want to be erased,
1- Create a new project in ReCap
2- Import a scan location other than "A", (the one you want to be erased). Set this scan location as your first register group.
3- Import your old project into the new one. Duplicated scan locations will not load (I think so, but if not, try to erase the scan location in the old project prior to import in the new one)
4- You can register the "old" project against the new first scan location. Since the "old" project and all their scan locations are already registered, it will be recognized as a registration group and then you will need only do a registration process: the whole group against your new first scan location.
regards from Spain.
In order to delete the top scan in group of scans do the following:
Here is the back story as to why I needed to delete the scan location in the first place:
I had to scan the complete level of a building on 2 different days with 2 different scanners and 2 different tripods of varying heights and 2 different iPads which means I wound up creating 2 different projects (1 for each day). Singularly both projects seemed to be fine, but once I combined the 2 projects the first scan of 1 of the projects set my 1st group of scans so that the Mirror Balls appeared to be in the ceiling. Once I viewed the project in 3D view I could see that only 1 of the scan locations was the root of the issue and it just so happened to be the top scan location (Murphy's law), hence the steps that I mentioned above in order to get rid of the top scan. I should also mention that this was done using the desktop version of Recap rather than the iPad version of the app, I hope that this helps.
Mitko, this remains an ongoing problem... and unfortunately, based on the suggested solution, i'm going to have to disband a group of 25 scans just so that i can remove the top one?!? Why is that?
Also, I REALLY wish there was a way to maintain the groups once all the scans are combined into one registered scan. For some reason, when i registered a scan from group 2 with a scan from group 1, ALL of my scans from group 2 went along (so far so good right?!?) but for some wonky reason, the whole thing is REALLY askew in some wild angles, and now i have to remove each individual scan from group 2 and start that one over.
The lack of an "undo" is 1 thing. But the lack of maintaining (and subsequently managing) groups seems frustrating.
Not to pile on, but sometimes, when i go to remove a scan, it will say "this is tied to the following scans"... is there a way to know that BEFORE trying to remove one? Can this be shown somehow?
Many thanks!
July 8th 2021, this is still an issue. I have to disband 60 or so scans. Very frustrating.
March 31, 2022 This still has not been solved and I am going to have to reregister 180 scans to delete the first one!
