ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Model is wrong orientated
7 REPLIES 7
Message 1 of 8
stephanreuter1457
652 Views, 7 Replies
the registered scans are wrong orientated. The roof of the model is not on the top of the coordinate system. What have I made wrong?
Thanks and greets,
Stephan
Labels (2)
7 REPLIES 7
Message 2 of 8
Hi @stephanreuter1457,
Thank you for participating in our Community! Would you be able to let me know what version of ReCap you are using and any screen capture or screen cast video would be very helpful for further investigation.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 3 of 8
I use Version 4.2.1.7. Attached a screenshot.
Greets,
Stephan
Message 4 of 8
Thank you for your reply. Would you be able to share created project and raw project data for further investigation? If you can then let me know and will share A360 project drive folder for uploading data.
Anil Mistry
Message 5 of 8
anil_mistry
in reply to: anil_mistry
I’m just following up to see if you were able to gather the information I had previously requested to assist me in troubleshoot your issue.
Anil Mistry
Message 6 of 8
under Display Settings -> Points (a box with dots) -> Update origin there is a macro to change the origin.
with TAB to change Z
and ALT to flip, you might be able to set the Z axis right.
Otherwise you have to indicate a point of the scan to make the new origin
and the direction of the X and Z.
After some trial and error your project may be ok.
Save as our Recap Project.
It might also be the case that as a final step you need to export the whole project into a unified RCS in order to have a cloud that has the right direction upwards.
As an alternative, start a new project, and manually import an register 2 of the RCS files of the support folder of your 1st project.
You might need to work with target points to get them in the right coordinates.
when these are OK, then import all other RCS files.
Message 7 of 8
I'm just checking in to see if you need more help with this. Did the suggestion that @Patrick_Aps_9121 provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 8 of 8
anil_mistry
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
Rail Community
