I have the latest Recap 360 Pro (April 2017) and having issues with assigning survey points to the project. Faro FLS scans included 4 checkerboard targets around a pump station building walls. I have successfully imported, registered and indexed 32 scans with no issues. All functions in Racp appear to work OK including export to E57 etc. I have been given the survey data (E, N and Elev) by the surveyor in Australian MGA-56 zone format. I created a TAB delimited txt file as follows:
2 6938544.174 502873.622 67.427
1 6938550.383 502866.878 67.413
3 6938558.714 502868.886 67.748
4 6938554.351 502874.971 67.533
Units are in meters. The txt format as I understand it needs to be ID, N, E, Elev(Z)
I first go to settings and set Co-ordinate system to "MGA-56" and for viewing set x=E, y=N and z=z.
Then I go to Registration page, find my targets and set them as Survey Points. In dropdown I first choose "Upload Survey Points (.txt) - [Survey format N, E, Elev]" and go find my file and pick it. Then back in dropdown I find the 4 ID numbers and choose the correct one for the checkerboard (1 is my first marker). Repeat this for markers 2 and 4. Marker 3 checkerboard does not get recognised because the Faro scanner photo on that marker was blown out by bright light. All done, I go back to the Project. It does some calcs and then bingo, the whole cloud turns upside down!! OK, bizaar, but if I go to the survey markers in 3D view and point at the centre of a previously selected survey marker, it is NOT correct. Maybe out by 1 meter or so on N or E. When I export upside down cloud to E57 and open in CloudCompare it starts upside down. Even there the co-ordinates are way off being accurate.
Why does the cloud invert? Why are the locations of survey markers so inaccurate?
I need some help please because my customer is relying on me setting the cloud to an accurate survey. I have spent a huge amount of time trying to figure this one. A challenge!!
Solved by terry4FWN6. Go to Solution.
Hi Terry,
Thank you for participating in our community!
Per your support case it appears that surveyor marked two survey points incorrectly and by correcting these points issue has resolved. Please, let us know if you have any further questions or concerns.
Thank you and have a great day!
Best regards,
