Hello @gsismanACAD,
I assume you're using UAV photos and ReCap's photo-to-3D service? If so, no need for RCM in C3D, as it has great support for the RCS point cloud itself. You can select RCS as the output of the service, so no need for ReMake in the normal case (although it's quite useful for editing/cleanup).
-Ryan
Ryan,
I was using the online meshing within a RECAP scan cloud project. Isolating a scan section and running it through the cloud service meshing.
I had a Light pole with a cobra-head and it sent me back an *.RCM file
OK - so you're starting with a point cloud (RCP) project. So why do you need a mesh for C3D? You can use the point cloud directly in there by attaching (PCATTACH) the RCP file.
If you're looking for better performance or visuals, you probably won't get that with a mesh - the Reality meshes are quite details and don't really render faster than point clouds (although the experience is still very nice).
I would suggest instead to just export your clipped area to a unified RCP file and attach that to C3D for your work.
HTH
-Ryan
