I have completed a 3D scan inside a large ship engine room to do a retrofit of the ballast system. All is registering well and I have the point cloud set up and ready to go into Plant 3D.
However, it is difficult to get the axis orientation exactly correct when using the "update origin" button in Recap; defining the axis by selecting perpendicular planes always leads to small errors. After probably a 100 tries I still end up with a small error in the axis orientation, which will without a doubt cause errors in the piping isometrics produced as compared to the real world.
Is it any way to define the axis directions manually in Recap without using the plane tool?
I've also tried manually rotating the point cloud in Plant 3D to make the vessel directions perpendicular to the point cloud directions, but this seems to crash P3D everytime.
Any suggestions greatly appreciated, thanks
