ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Long time for change region....
7 REPLIES 7
Message 1 of 8
d.cotret
347 Views, 7 Replies
Hello
I have a projet with FARO scene import (20 scan) and trueview, my projet size : folder 3.41 GO and rcp 650 Ko
All is ok for import scan, move in scan....
My problem, i have create new region, and i send selection cloud in this region.
I used limit box for my selection, and regions are off.
After this operation the size to folder don't change but rcp have 80.Mo and the time for select new region is 10 min or i have e recap fatal error....
I have testing on different computer and probleme is same......
What is the solution, i don't have add new cloud in projet, only transfert point in region.......
7 REPLIES 7
Message 2 of 8
vidanom
in reply to: d.cotret
Hi @d.cotret,
There will be some improvements with ReCap in its next update and the way it handles regions, but until then the workaround when creating 5+ regions is to export them as new RCS file and import those files back into ReCap. The performance should get back up once you do that.
This happens when there are close to 10 regions, or the selection for the regions is consistent of complex add/remove selections by using the fence tool.
Hope this helps,
Mitko
Message 3 of 8
d.cotret
in reply to: vidanom
Hello thank, i have used this technique before receive your message, but i a a new scan project for a factory, in first time i have cut my scan in 8 part, after i have work in all part for create new region for each equipement add after 1 hours of work problem is same
For me the proble is recap reload all last operation when you start new fonction, is not possible don't save history ?
We don't have this problem with 2015 recap....
Thank for ypur help
Message 4 of 8
ashwini.murthy
I am sorry you are experiencing this issue. ReCap 4.0 has some improvements for selection, creating regions and adding points to regions.
@yan.fu has some workarounds for further improving the performance of regions - https://forums.autodesk.com/t5/recap-forum/selecting-points-and-scan-regions-are-very-slow/m-p/69772...
Re-posting the same here:
"However, we have some small tips on how to improve the performance when editing the projects:
1. Use more regions instead of putting a lot of selections into one region. The performance majorly depends on how many selections you have made instead of how many regions you have. Splitting big regions into smaller ones will help to improve the performance especially when you want to lock / hide that region, i.e. make regions to be locked / hidden contain fewer selections.
2. Although plane selection is very useful to select points, it scarifies some performance since plane bound can be as big as project bound, which spans more area compared with using rectangle selection with limited bounding box.
3. Keeping your selection as tight as possible to include only the points you want to select also helps to improve performance.
4. Use clip tool to aid your editing process when you want to temporary hide something."
Hope this helps.
Ashwini
Message 5 of 8
in reply to: ashwini.murthy
I just updated my recap (because it kept on reminding me).  I do not have Recap pro but I've always been able to use regions.  With the new release of Recap, regions are now a pro feature.  Is this correct?  I won't be able to use regions anymore?
Message 6 of 8
anil_mistry
We made two changes to the region system in ReCap 4.0:
  1. Improved the performance of creation, loading, and interactive navigation for projects with many regions (see Release Notes for more information).
  2. Made region authoring a feature of ReCap Pro. Non-subscribers can still view and export regions, however ReCap Pro is required for region creation, renaming, deleting, and other operations which modify the regions in a project.
Please, let me know if this helps.
Thank you and have a great day!!!
Anil Mistry
Technical Support Specialist
Message 7 of 8
Patrick_Aps_9121
I think that the Import Regions from a CSV file would help you a lot.
just create an TXT file containing
Region1_name;Xmin;Ymin;Zmin;Xmas;Ymax:Zmax
and rename it to CSV
But as of version 4.x you need the PRO (trial) to do that.
Message 8 of 8
anil_mistry
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Thank you,
Anil Mistry
Rail Community
