Loading Scan
Loading Scan
ewing
Loading Scan
ewing
I have quite a few ReCap models with different amounts of data in each. The one I have now is only 4 stations. Each time I go to a different scan location by clicking on the bubble indicating that view I wait about 10 minutes at the Loading Scan dialog. Is this normal? Am I not registering this stuff correctly?
Patrick_Aps_9121
Try using Save As to save the whole project on a local C:\ drive, or another local SDD drive. Do not use USB drives, they may time out and go into powersave while the data is read.
anil_mistry
Autodesk Support
Autodesk Support
Hi @ewing,
I'm just checking in to see if you need more help with this. Did the suggestion that @Patrick_Aps_9121 provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @ewing,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Anil Mistry
