launch recap 360 web returns er0000
Kevin.Spear
Kevin.Spear
It does not matter if i use Chrome, Edge or Firefox; launching recap360.autodesk.com loads the environment but cannot find any of my data online. I get er0000 which says to check the forums for a solution. And here I am... anyone?
Kevin
Kevin Spear, PE
Kevin.Spear
ironically, later today this error stopped appearing. I had been getting that error for 2 weeks. I finally post the issue and it magically works.  Maybe I'll do that more often...  🙂
Kevin
Kevin Spear, PE
I am getting the same error. Hopefully by posting here Autodesk will fix it for me too 😛
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! This error may have caused by corrupted RCP project. If you recently created a project and published to web, then delete this project from A360 Drive project folder, then try viewing again.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
eli92TVX
Observer
Observer
4-Years Later and I'm getting the same error??
I have yet to successfully Launch any 3d Model or Publish any Recap Project, using any browser... This does not strike me as a fully-baked solution, of the quality I expect from Autodesk.  😕
