ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Latest Updates | New Knowledge Network Articles | ReCap
1 REPLY 1
matthew.d
723 Views, 1 Reply
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for ReCap?
(List shown in chronological order)
 Subscribe to receive updates for new ReCap's Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
1 REPLY 1
matthew.d
in reply to: matthew.d
December 2017
Measure areas in Recap Pro
ReCap 360 Mobile Crashing with HDR scans
ReCap cannot be started and 0 days left
Recap Photo: File size limit per picture file that can be loaded in recap photo
November 2017
How to download and Install ReCap photo
How to take the right photos to be used for ReCap Photo
Licensing issue updating ReCap 360 to Recap 360 PRO
ReCap 360 Error Unexpected Exception Code RE3100
Recap Photo: Aerial project has wrong Z coordinates
Recap Photo: Manually stitching photos
Recap project upload error after “Save as” process
Unable to import a scan into ReCap Mobile
October 2017
How to move or rotate a model in Recap photo
Recap Pro: Mesh creation result is larger than expected
Recap Pro: PCG file format export missing
New Recap Photo and student license
Does the codec required for MP4 view state output come with ReCap?
Can ReCap support GoPro Omni and Nikon KeyMission 360 cameras
September 2017
ReCap: After a few region setups the program performance slows greatly
Rendering an AVI from 3ds Max displays half of the rendered video output in green
Performance issue with ReCap Pro
ReCap: How to use enhance registration with targets
August 2017
Recap error: You don’t have enough disk space for the importing
Register one LAS point cloud in Recap
How to create Scan-to-Mesh or Object Mesh in ReCap 360 Pro
Error “ER0000” when try to open point cloud project in ReCap 360
How to redo manual registration once registration is accepted in the field on ReCap Mobile with the ...
adding scans to existing ReCap project from ReCap pro mobile app
Limit file sizes in Recap Pro
Pointcloud imported from PTS file does not load all stations
How to view Real view images from ReCap project in Virtual Reality
Importing a LAS file into Recap results the point cloud being in the wrong location
How to view thermal photos taken with the scanner in ReCap using BLK360
Recap Pro and project data in the cloud
How to level point cloud using survey points in ReCap Pro
July 2017
How to Download ReCap 360 Pro and activate
How to get a Free Trial of ReCap Pro from ReCap (Standard)
Unable to transfer ReCap project from iPad Pro to Recap Pro desktop application
OpenGL error when starting Recap
Purchasing previous versions of Autodesk software
Recap crashes on startup
June 2017
Importing LAS format is not working in Recap Pro 4.0.0.28
What is a Structured Scan data in ReCap 360
Is it possible to get the GPS-information of the scanner to ReCap?
It is not possible to delete photo project on Recap 360
ReCap: is not working using Mac Book Pro in Parallels or VMWare environment.
May 2017
Photo project photo upload stalls and will not complete processing in ReCap 360 web
Recap 360 Error Unable to Initialize Code RE3101
Recap Pro workflow tip registration for large projects
April 2017
Recap shows thin lines in the panorama images
Support of Recap 360 on mobile devices
March 2017
CLR scan files cannot be loaded into Recap
Faro FLS data cannot be opened in Autodesk Recap
Recap sync error when opening a project
Switch or flip X, Y or Z axis orientation during data import
February 2017
Recap displays error message when trying to create a Scan to Mesh
How to combine photo scan project in the ReCap
Points deleted in ReCap reappear when the project is loaded into AutoCAD
Point cloud is not created correctly when using LAS file in LL84 coordinate system
January 2017
ReCap 360 coordinate transformation
Autodesk Desktop App error when updating ReCap
Change point registration quality filter
Matt DiMichele
Rail Community
