last update Recap Photo 19.1.2.20, the coordinates system lost
gustavo_bergoya1
gustavo_bergoya1
Hi group,
With the last update of Recap Photo 19.1.2.20, the coordinates system is lost.
Regards
I have the same issue with Recap Photo 19.1.2.20.
I can´t select the coordinate system because the box is empty, so I got the same error "the target coordinate system is not valid".
Besides, I tried to check it through "ground control points" option, but since updated ReCap photo crashes and closes.
I having the same problem 😞
I also have the same error. Has a solution been found????
There is an update that fixed this. Uninstall the entire Recap and install the latest version so it will work as normal. Now there are problems that GCP points measured with GNSS do not match what comes out with Recap Photo. Heights and XY are wrong.
