Is there a way to embed recap viewer into a company website?
Maybe this is a developer's topic... trying my luck to see if we already have a solution here. Thanks.
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our community! I believe this is not supported at this time but let me check with development team and will give you an update back.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
jblTV3QG
Is there a solution for this? i need to embed to company website 3D Scans in rcp format or rcs such that my clients can see case studies.
Is there a way to embed recap viewer into a company website? You said you would look to see if this was supported. Is it?
daniel_musick
You can export images from ReCap and even export a video from several view states.
Then maybe generate a GIF from the video, so that you can show your work on your website.
