Hi, i apologize if there are repeated posts for this topic but i've been trying to download recap 360 pro student version for quite a few times, even running on admin. However, it always stops at the initialization phase, where it will initialize for hours to no avail. May i request assistance from anyone who can help me with this issue?
Thank you!
Benedict
Solved by natasha.l. Go to Solution.
Hi @Anonymous
Could you check if you have turned off the fire wall and any anti-virus program during the installation?
Hi, i have the same problem. I want to install ReCap360 student trial. I have disabled all firewalls and anti virus (bitdefender), updated graphic card driver. Tried with Microsoft Fix-it to see if there was anything. I managed to install an older version of Recap 360 using some manual install feature, called app managment, on your website. But I would like to try the Pro version. The exact same happens when trying to install Netfabb 2018. Get stuck in installation during "initializing"....What should i do?
best regards
Hello @Anonymous,
Try the following steps, there shouldn't be a problem with the download you can try a different method of download & some better preparation steps to help resolve this & get Recap Pro installed.
Keep us posted on the progress.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Just checking in with you, hope you were able to resolve this.
Natasha
Helpful Links:
Hi again..
The problem persists. Followed all the steps. Still stuck at initializing 😞
I even uninstalled Bitdefender completely (with reboot)..
Its not an option to get recap pr through autodesk virtual agent? That seemed to work for Recap 2015 (i uninstalled that also before trying)
Best Regards,
Hello @
Please try the steps above & then use this Recap Download Link to download & install. The Recap activation process is different in that it recognizes your Autodesk credentials & determines what you have access to ReCap, ReCap Pro & ReCap Photo.
Just in case you do not have an Educational Community account, please review this >post < on how to, it will provide you with the information you'll need to activate educational software.
Natasha
Helpful Links:
Hello @doctorupdonk,
Please let us know if you have any more questions. Let us know if you need any more help installing ReCap, I have created a post that may help you out:Installing ReCap & ReCap Pro with ReCap Photo
Keep us posted. 🙂
Natasha
Helpful Links:
Hi Natascha,
great now it worked 🙂
Is there a similar download link for netfabb?
best regards.
You can grab the download from your Educational Community account & select it from the drop-down it will take you to a page where the activation information will disply for you to activate.
Natasha
Helpful Links:
I see there is a problem with the Netfabb Standard 2018 in the Edu community site it is not the proper download option, Browser Download link in the drop-down, sorry about that. I will reach out to have them fix this, but I have provided it below:
Netfabb 2018 Windows 64bit
Thank you for continuing to post to the community.
Natasha
Helpful Links:
