Hi
How can i increase my A360 size, as there is so many different options of A360 Drive, 360 Teams etc..
At the moment my account only has 5GB.
J
A360 drive size is included with some of the products that you have an active subscription to. Whoever manages your Autodesk licenses can check if you have access to the larger A360 storage. I believe that 5GB is the free amount.
ok thank you.
unfortunately at work we still work of serials and not user accounts 😞
also i have one scan job that is 110GB so i am guessing there is no way of using this service, as its only 25GB on a subscription account?
It does not appear that it a solution for you. But even with serial numbers, someone in your company would have a Autodesk licensing account to manage the renewals. In manage.autodesk.com, the account manager could add users.
But, based on your data set size, increasing to 25GB would not help.
For sharing our scan data with external partners, we have used Assemble (they have a addon that allows you to view point clouds - works pretty well) and Revizto. I am not aware of any other free options.
