In Recap project file (.RCP) structure scan files path missing
Now i have started using Recap, I have copied one recap project files & its supports files to local drive from server.
If i open the .RCP file in Recap, then i am getting question marks on the supporting files attached. When i move cursor on that file, it shows the file path which is on server. They are not taking path of local drive where i saved the supports file (all supporting scan files are in one folder & just outside of that folder there is project file .rcp)issue.PNG
So how can i change the path of supporting files(structure scan files).
florian.scheidler
Just click on the question mark inside the bubble. You will have the possibility to reference the new location of the support folder. Once refering to the new location of one file, Recap should be able to find the new location of all the other scan files if they are in the same folder.
