Dear Ladies and gentlemen,
In the moment I´m trying the free trial version of ReCap / ReCapPhoto and I want to tell about my experiences with it.
I´m not new to Autodesks Photo – to – 3D – solutions; in the past I used 123dCatch and ReMake, which worked fine. With ReCap, it’s a different thing – I cant get one useable result with the photo – to – 3d ( object ) method. Only one half of my models ( skull parts ) is created correctly as a mesh, the other half is not created, although the photos show this side, too. I tried everything – Starting with several fotosessions with different light situations, an increasing number of photos to be sure every aspect of the model is visble until painting the model, so it is no more glossy. I manually stitched it with ~ 20 survey points from every angle – always the same result with or without manual stitching ( The stitching process is not good explained on the Autodesk help pages. I found the Autodesk-video with the Laocon-group about this process on youtube ). With ReCap Photo it is still the same - which took almost all my credits for bad results.
Maybe my feedback is helpful to improve the software. In the moment, I wouldn´t buy a ReCap license.
With my best regards,
Simone Rößling
VCT GbR
Frauenbergstr. 21
35039 Marburg
Tel.: 06421 / 483259
ACHTUNG: neue Mobilnummer:
Mobil: 0151 / 28797130
Skype: vct-3d-animation
www.vct-net.de
Simone.Roessling@vct-net.de
Solved by murali.p. Go to Solution.
Thank you for reaching out to us.
ReCap Photo's Object reconstruction option and ReMake uses exactly the same web service, hence the results will not be different.
ReCap Photo desktop application does not have the capability to enter manual stitch points for Objects. Hence I am not sure we understand your problem well. Could you please elaborate?
Murali
I'm just checking in to see if you need more help with this. Did the suggestion that @murali.p provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Thank you for your reply and I am glad to hear that the issue is now resolved. Please, let us know if you have any other questions or concern.
