Implementing Coordinates
I'm having trouble understanding the proper way of implementing coordinates into recap pro.
I'm given a Civil Survey with multiple survey points and not sure how to do this in recap.
Set 1 will have: NE, S, & W I'm assuming the Z will be the CB or MH
Set 2 will have: W, W, NW
And so on.
I watched videos of where after you complete your rcp file, you hover over the Home incon, then select registration but the coordinate system isn't in the list and I only see x, y, &z
If I were to start over, I can import the fls files and that gives me an option right away under the advanced tap and able to select current and target coordinate system but I do not understand the purpose of "Target" and it will not allow you to continue unless you select at Target.
If I were to start over using existing rcs files, I do not get the option in the beginning.
Also, I cannot find:
NAD 83 New York Central Zone (3102) US feet
