- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My goal is to compare and try fitting the alignment between the 3D CAD Model and Point Cloud data.
I figured that Recap Pro is one of the ideal solutions for it.
So I researched about importing 3D CAD Model into Recap Pro, but I was not successful thus far.
I tried the suggestion of downloading NWC Export Utility and use it to export the .dwg file to .nwc, but I couldn't find the option to save or export the CAD model to .nwc file. in my AutoCAD 3D and Navisworks. None of them supported this feature even after installing the utility.
I searched similar questions, and this was the only answer I found through Autodesk community, which didn't work out in the end. I don't know what other ways I can make use of CAD model on Recap Pro, is there really no way out of this?
Thanks.
