I can not upload photos at recap.autodesk.com there is no photo to 3d option
help me please!!!
Solved by anil_mistry. Go to Solution.
Hi @erickcrm,
Thank you for participating in our Community! You can't create ReCap Photo project from recap.autodesk.com anymore, you can create Photo project via ReCap photo which is part of ReCap Pro. Do following to lunch ReCap Photo application:
1. Lunch ReCap Pro
2. Click on New Project from deshboard
3. Click on Photo to 3D to lunch ReCap Photo application
4. Within application select Aerial or Object to process ReCap Photo project.
Let me know if this helps.
Thank you and have a great day!
Thank you for your help
but when I click photo to 3d
I'm directed to https://recap360.autodesk.com/
and there is no photo to 3d option
only the search icon
I was able to solve the problem I installed the recap pro 2019 and I was able to use the recap photo
