ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
How to synchronize unstructured LAS
2 REPLIES 2
Boeckelken
238 Views, 2 Replies
I'm using ReCap 4.0 (2018) to prepare LAS data for using this in NavisWorks and InfraWorks.
Now I have a problem with two unstructured LAS files. I want to combine this both to one rcs file.
The problem is that the data is not "overlapping" correctly. There is a difference of around 1m in X and Y.
I have absolutely no idea how to fix that.
2 REPLIES 2
vidanom
in reply to: Boeckelken
Hi @Boeckelken,
Do you think this misalignment was because of ReCap?
You should be able to move the scans in Navisworsk or Infraworks manually.
Will that work?
Mitko
Hello @Boeckelken
is there a gap between the scan data when you say "not overlapping"?
Or have identical points different coordinates in both scans?
If it's only a gap between scans you should be able to start a Recap project with the first LAS file. Then add (import) the second LAS file. It will be placed at the correct coordinates.
Karsten.
Karsten Saenger
Rail Community
