Hi @Boeckelken,
Do you think this misalignment was because of ReCap?
You should be able to move the scans in Navisworsk or Infraworks manually.
Will that work?
Mitko
Hello @Boeckelken
is there a gap between the scan data when you say "not overlapping"?
Or have identical points different coordinates in both scans?
If it's only a gap between scans you should be able to start a Recap project with the first LAS file. Then add (import) the second LAS file. It will be placed at the correct coordinates.
Karsten.
