How to open the mesh file?
Dear sir,
After finishing mesh operation, i can't find obj file in A360 Cloud.
how can i open "WT_" no extension file or "WT.smm"?
Ivan
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! Where did you create Scan-to-Mesh/Object Mesh project? Did you use ReCap Pro to create your mesh? If you did then you will have output format in OBJ or RCM. You can Open RCM files using ReCap Photo. Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am just wondering if you need additional assistance or you were able to view this file.
Anil Mistry
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
