How do I make different version of a Recap file?
chris
chris
Here's the issue I'm having, I want to take the recap file and create different versions of it.
Example:
In one version I want to hide/delete/suppress (whatever the correct term is, all of the point-cloud except one portion that I then want to export to .obj
Then I need to do the same thing but with another portion of the point-cloud.
Up to now I have been deleting the selected areas of the point cloud, exporting and then re-downloading the point-cloud and starting over with the next section, but there has to be a way for me to create different versions of a single point cloud? (At least I hope there is)
daniel_musick
"export to .obj" ???
You can export the scan in a number of different file types. These include: E57 structured (complete...
You might want to look into scan regions.
I would advise you to finish the clean up of the ponitcloud and then removing the deleted points before you start creating scan regions.
