Exporting regions to csv file
siem.vaneyndeJ5G6C
siem.vaneyndeJ5G6C
In Recap there is a possibility to import csv-files to create regions.
But how to export region info to a csv-file?
I would like to include existing regions into a new point-cloud revision, but the only way is to redifine all regions?
If I can have a csv-file from my current regions, I can import it into the revision.
Thanks!
anil_mistry
Autodesk Support
Autodesk Support
Hi @siem.vaneyndeJ5G6C,
Thank you for participating in our community! At this time Scan Regions can be exported as RCP, RCS, PTS, E57, or PCG file formats only. This is an enhancement request and If you have any feedback that you would like to submit regarding any enhancement, please click on the “ReCap IdeaStation” link on the ReCap community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
siem.vaneyndeJ5G6C
@anil_mistry
At the moment, there is no workaround for this?
I can't determine coördinates from a placed region?
peter.hintze
Hello, are there any updates on this? I also would like to export a CSV (name, x min, y min, z min, x max, y max, z max) based on my defined Regions. Exactly the way the Region-import format looks like.
