Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
E57 Import to ReCap severe decimation
12 REPLIES 12
Message 1 of 13
2933 Views, 12 Replies
I am trying to import a 19GB E57 file into ReCap (export from Faro Scene), I have also tried with an entirely separate scan that is 15GB. The file imports and creates an RCS that is approximately 1/10th of the size of the original E57 file. The point spacing appears to be reduced to an approximate 30mm x 30mm grid which is unusable for my purposes. I have checked all of the settings in ReCap and tried with decimation both off and set to "0".  The file created is slightly larger when decimation is set to "0".  I have tried this multiple times with multiple files and am getting the same result.  This is my standard workflow for the past year and I am just now running into this problem.
Thanks for any help,
Nik
Tags (3)
12 REPLIES 12
Message 2 of 13
ryan.frenz
Where did the E57 come from?  Could it somehow have been written in inches?  The grid size you quote could possibly be explained by that.
Just some thoughts.
-Ryan
Message 3 of 13
in reply to: ryan.frenz
It was exported from Faro Scene and dimensionally everything is on in the scan itself. And in theory it shouldn't even mess with density when I turn off decimation entirely (or set it to "0").
Message 4 of 13
ashwini.murthy
Hi @Anonymous,
I am not seeing this issue with the E57s that I have. If you don't mind sharing your scan, I will be happy to check it out. I can share a Box folder to facilitate the upload.
Ashwini
Message 5 of 13
Hi @Anonymous,
I was wondering if you had an opportunity to gather the information that @ashwini.murthy requested yesterday to assist her in troubleshoot your issue.
Thank you and I look forward to your reply.
Anil Mistry
Technical Support Specialist
Message 6 of 13
in reply to: anil_mistry
I will try to gather a cropped version of the scan that is easily transferrable.  As a side note I exported from Scene into a PTX file then imported and it worked well.
Message 7 of 13
anil_mistry
Hi @Anonymous,
Thank you for your reply and I am glad to hear that you were able to export PTX from Scene and importing into ReCap works for you. Please, let me know when you have scans for me to do further investigation.
Thank you and have a great day!
Anil Mistry
Message 8 of 13
Attached is copies of a small section of the scan that I have exported into an E57 file then imported into ReCap RCS file.  Decimation is turned off, the RCS file is approximately 1/10th of the size of the original E57 (which is usually approximately the same size).  Also the point spacing in the RCS file appears to be approximately 3cm.  Let me know if you see something I am missing.
Since Autodesk doesn't allow the file extensions E57 or RCS I have changed them to allow me to upload these small point cloud files.  You will have to download and rename to open.
Test.GIF needs to be renamed to Test.E57
Test.JPG needs to be renamed to Test.RCS
Nik
Message 9 of 13
anil_mistry
Hi @Anonymous,
Thank you for sharing these files with us we will try to duplicate this behavior on our test environment and will give you an update as soon as possible.
Anil Mistry
Message 10 of 13
Thanks for sharing the E57. Have you tried importing it in any other tool.
ReCap is not performing any unwanted decimation. I tried importing the scan in CloudCompare and ReCap, the point cloud looks decimated in both tools with default settings (attached image).
-Ashwini
Message 11 of 13
in reply to: ashwini.murthy
Thank you for following up, I was just writing that I had tested it a few different ways and it appears that it is being decimated on the export out of Faro Scene.  I will pursue corrections from that side!
Thanks again,
Nik
Message 12 of 13
I figured out that this is happening on projects with very large numbers in the coordinate systems like state plane etc... Moving the (0,0,0) of the point cloud closer to the actual scan fixed my problems.  There were work arounds like exporting in different formats but overall this was the best solution.
Message 13 of 13
-Ashwini
hi
me i tried to import it in a tool i forget his name but its very efficient tool
if i memory his name i will say it to you
Rail Community
