Before I spend 5 Autobucks on a test... Does Photo to 3D support a mix of nadir and non-nadir source images? I'd like to combine photos from a nadir mapping flight with angled photos from one or more POI flights to improve the detail and accuracy of specific buildings on the site. Ideally I'd like to get both a georeferenced ortho tiff and an rcs point cloud for use in Revit.
If this is supported, what are the best settings? Should nadir optimization be on or off? Any other recommendations?
Solved by dpouliq1. Go to Solution.
The nadir optimization should be on only when ALL photos are nadir ones. If you process a mix of nadir and obliques (which is possible), the nadir optimization should be set to off.
Regards.
Dominique Pouliquen, Autodesk, Reality Solutions.
