ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
counting scan points
1 REPLY 1
rwuethrich
105 Views, 1 Reply
Guten Tag
kann ich die Anzahl Punkte zählen aus dem 3D Scan
danke für die Hilfe
Good day
can I count the number of points from the 3D scan
Thanks for the help
1 REPLY 1
zhaoyang_ma
in reply to: rwuethrich
Hi @rwuethrich,
You can hover your mouse over a scan under "Scan Locations" in the project navigator in ReCap Pro. There is a tooltip for the scan. The tooltip message contains information about the number of points the scan has.
Note:
  • The number could be written in the format of "1.23M". So you might not get the exact number, e.g., if the exact number is 1230001
  • Invisible points (including hidden points, points outside of limit box, deleted but recoverable points, etc. ) are counted as well.
Reality Solutions SDK can be used to programmatically get the number of points in ReCap projects or scans. For more information about the SDK, you can refer https://aps.autodesk.com/developer/overview/reality-solutions-sdk
Best regards!
Rail Community
