Converting stl tri-mesh into quad mesh
Florian__
Florian__
I made a 3D Scan of a parabolic dish. Now the plan is to create a solid in Fusion 360. Therefore I found out that a quad mesh can be used to create T-splines and then making a solid out of them.
After exporting the mesh in ReCap as obj quad Iget the following error.
What can I do to fix that?
Thank you
barmanr
Hi @Florian__ ,
Could you try using the Diagnostics tool in ReCap Photo to auto fix the mesh and try exporting again?
Thank you for the mesh. I will give a try on my end using the stl you provided as well.
Warmest Regards,
Rishov Barman, Reality Capture
Rishov Barman
Reality Capture
Florian__
Great thankyou. I never noticed this feature.
