I have a FARO Focus 3d scanner and use it in my line of work to scan my customer's equipment to collect data so I can use it to engineer products for them (I'm a mechanical engineer). I spent a number of hours today cleaning up a set of scans I brought into Recap. When I use the mesh generation service, the file(s) I open in either Remake or Inventor have a lot more garbage left in them- actually most of what I spent a lot of time cutting away. the file isn't terribly large, composed of 12 scans. The RCS file is 18mb, the mesh is 52mb, and the RCM file is 31mb. I am running Windows 10 (64 bit) on an 8 core Intel Xeon e5-1620 v4 @3.50 GHz with 40gb ram and a twin 1TB RAID 1 hard drive setup.
1. Why is there a bunch of deleted data remaining in the newly generated mesh even though my project has been optimized? I also unified it into an RCS file for kicks but the only thing I know I can do with it is insert it into an Inventor assembly as a point cloud. The problem with this is I need to have it represented in a drawing file, which is why I'm going the mesh route.
2. After finishing all of the above editing, ReCap now acts horrendously slow. Zooming and panning are almost impossible. All I really want to do still is to change the limit box but Recap can't seem to handle this. Earlier, Recap acted quite normal and fine.
3. When bringing the mesh into Inventor, the scale is grossly off. Where an object should be 20-24 inches or so, it's more like 1/2".
4. I'm not convinced that I actually need ReMake to do my work (currently using a trial version), but I'm unsure and know that it is a primary program for editing meshes where ReCap doesn't and I think anything like that in Inventor would be very arduous.
Part of what I need, I think, is to have a discussion with someone at Autodesk who is well acquainted with all of these products and Navisworks. Who can help me?
Adam Wright
