Using Recap Pro - trial licence. I am attempting to publish my project to the object mesh service, but get locked into a continual publish request?
Can anybody help?
Regards
RAB
Solved by ryan.frenz. Go to Solution.
Hi RAB,
There is a known issue where this can happen if the project contains 'unstructured' scans (from UAV photos or generic point clouds like PTS/LAS/etc). These scan types aren't supported for publishing, which triggers this UI quirk (the app just sees that all your scans aren't published).
If this is the case, try hiding these scans in the Project Navigator (right-hand pane) before requesting the mesh - this will cause them to be ignored in the check.
Hope this helps,
-Ryan
