Can we export a particular type of feature from LAS file in individual files
I have open las files in Recap but cleanup tool is disabled and can i export some feature from these las files in a individual file for draw the vectors
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! You can create region and then you can export this region out from ReCap pro. Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Is there any tool for auto extract feature from las file and while opening .LAS file in AutoDesk Recap Pro, its show Unstructured data. Are all .LAS file consider as Unstructured data in Recap Pro?
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your reply. As far as I know there are no tools to auto extract some feature from LAS file while opening in ReCap Pro. Structured scan data is mainly coming from Faro, Leica, Z+F, Riegl, Topcon & Trimble 3D laser scanners in the format of .FLS, .PTG, PTX, ZFS, CLR, RSP and RDBX scan files respectively. These file formats, and some types of binary E57 scan files, are primarily structured scan data. Please see this Forum post for more information. Let me know if this helps.
Anil Mistry
yan.fu
You can try Autodesk Infraworks, which provides more feature extraction tools for laser scans.
Yan
