BUG: Classification lost when importing XYZ or TXT data
peter.hintze
Message 1 of 9
peter.hintze
Issue:
When importing XYZ or TXT data (and defining the culumns via the import dialog: X,Y,Z,R,G,B,Classification). The classification values are not imported into the resulting RCS file.
Expected:
Classification in XYZ file should be imported into the resulting RCS file.
see attached txt exmaple file
Replies (8)
Message 2 of 9
Pointdump
Hi Peter,
What does the Classification Value represent?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 9
yan.fu
Hello @peter.hintze ,
This is a limitation of current ReCap version.
ReCap loads the classification information from raw scans and saved the classification into .rcs files, however, the classification information is not visualized in ReCap and the classification information cannot be exported.
Better support for classification information is in our Roadmap.
Thank you for your feedback.
Best Regards,
Yan
Message 4 of 9
peter.hintze
Hi @yan.fu ,
thank you for the answer. I don't refer to the missing option to visualize classes in  Recap - I really am refering to the fact, that the resulting RCS file has no classification values anymore from the original XYZ file. When i load the file e.g. into Map 3D / Civil, it already says so in the "Details" report of the RCS file import/attach-dialog. And once imported, the option to visualize the classes in Map 3D / Civil is also greyed out.
When i use LAStools' "txt2las" to convert the XYZ file into LAS and then import the LAS file into Recap creating an RCS, the classification value are saved into the RCS and can be displayed in Map 3D / Civil. But this workaround needs more unecessary steps.
So, my only explanation is, that Recap loses the classes when creating the RCS file even though i have defined the related column in the XYZ-import dialog.
Could you check?
Thx, Peter
Message 5 of 9
yan.fu
Hi @peter.hintze ,
We have logged an issue for it and the dev team will look into it.
Thank you!
Yan
Message 6 of 9
Pointdump
Peter,
While you're waiting for Autodesk, here's your TXT file converted to LAZ in LASTools. I used "-parse xyzRGBc". Now you have:
histogram of classification of points:
   164155 ground (2)
     34041 low vegetation (3)
      11717 medium vegetation (4)
  164650 high vegetation (5)
     17847 building (6)
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 9
peter.hintze
@Pointdump Thank you! 😉
Message 8 of 9
TerryDotson
The conversion process to .LAZ should be considered an absolutely necessary step.  In storage the .TXT file is taking 12.5x the amount of space, to anyone not familiar with the project there is a possibility of confusion of what the columns represent.   Before emailing the .TXT you should ZIP them anyway, would have to on large files.
The .LAZ format should be the standard storage format.
Message 9 of 9
klarinda.gunadi.widjanarko
Hi @peter.hintze ,
We have made a fix for this in ReCap 2023.
Can you try it to see if it works?
Btw just some note, if you have ReCap 2022 installed, please uninstall it first before installing ReCap 2023.
Thanks.
Klarinda Gunadi Widjanarko
Senior Software Engineer
