ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
ReCap Forum
Post 1 of 11
Best point cloud for indexing
123 Views, 10 Replies
12-09-2016 09:41 AM
For indexing in Recap, what is the best type of point cloud to export from Cyclone?  I have been using e57 for a long time, but was just told that PTGs are the better for whatever reason.  What does Recap recommend?
Post 2 of 11
Re: Best point cloud for indexing
12-09-2016 09:54 AM in reply to: jared.white
I'd recommend PTX or E57.  PTG is Autodesk's older point cloud format.
Post 3 of 11
12-09-2016 10:02 AM in reply to: michael.riley
Hi Jared,
There is also a known issue with importing Cyclone-generated PTG files if you have deleted a lot of points. Cyclone will still output those points, but with zeroes for values. This tricks Recap's importer into thinking that there are actually points at the origin of the coordinate system, and so it's as if the scan's bounding volumes are larger than they need to be. In this case, I would recommend E57.
Otherwise, it shouldn't matter much. PTG is often faster to import/export, but it all depends on the content of the scan.
Cheers,
Dave
Post 4 of 11
12-09-2016 10:34 AM in reply to: daverudolf
This makes sense..  The problem that we have that i was hoping a PTG would fix is the naming.  Our scanner names the scans, but recap re-names them randomly when indexed.
Post 5 of 11
12-09-2016 11:29 AM in reply to: jared.white
What type of scanner are you using? Recap should keep the same file names for single-scan file formats, though it does rename file names for multi-scan formats (e.g., an E57 file with multiple scans in it).
Highlighted
Post 6 of 11
04-13-2017 09:45 AM in reply to: daverudolf
We use a Leica P40, which unfortunately does not cooperate with recap directly.  We are hoping that Leica's new relationship with AutoDesk (aka BLK360) will open things up so we can import directly from the P40 into Recap.  I believe that Leica needs to release the rights to do so.
Post 7 of 11
04-26-2017 06:46 AM in reply to: jared.white
Jared, Did you determine what is the best format a to import into Recap from a P40
Post 8 of 11
04-26-2017 07:01 AM in reply to: chad.kopecky
Yes, we have determined that PTG is the way to go.  It is binary, making it smaller in size, and carries the scan location and color information.  E57 spits out structured, and unstructured data, which messes up the RCS names, and you  have more rcs files than the number of actual scans.  PTX is not binary, so the files take way to long to export, and takes up about 70% more space on your hard drive.  No export will have the same names as the original cyclone database, because it exports the scans randomly.  However, the RCS files will match the PTG file names.
If you bring the raw scans into a cyclone registration and freeze it (with all the scans on top of each other), you can export the PTGs and register them in Recap.
Someday, maybe Leica and Recap will allow us to import directly into Recap from the scanner.  We can only dream.  : )
Post 9 of 11
04-26-2017 09:17 AM in reply to: jared.white
Jared thanks for the reply.
So the only way to for this to work is to register in Recap?  What is the difference if I bring in a registered PTS file?  I don't get the scan setups?
Haven't used registration is Recap can I do a visual registration as easily as in Cyclone?  No targets on this scan with about 30 setups.
Post 10 of 11
04-26-2017 09:38 AM in reply to: chad.kopecky
No you can register in cyclone if you prefer.  I still recommend exporting PTG even if it is registered in Cyclone.  If you export a PTS, the RealViews (TruViews) won't come in because they don't carry setup information.  On small jobs like the one you're talking about, we try to register in Recap, because it makes the Real-views and the RCS files in the same project.
Post 11 of 11
04-26-2017 12:34 PM in reply to: chad.kopecky
Is there anyway to get the photos from the P40 into Recap?
